If they are not running efficiently, they send an email to the service provider. The attached code is used in testing on the bench.
It uses several bits of code from the forums to get the job done. This is running on an Adafruit Huzzah Feather and has the Branch 3 basic code.
Cheers,
Tom
' hvac monitoring system development, Apr 10/17
memclr
' allocate arrays
dim add1(8)
dim add2(8)
dim add3(8)
dim stat(5)
dim pres(5)
' initialize switching pattern
' for address decoder chip
add1(0)=0
add1(1)=1
add1(2)=0
add1(3)=1
add1(4)=0
add1(5)=1
add1(6)=0
add1(7)=1
add2(0)=0
add2(1)=0
add2(2)=1
add2(3)=1
add2(4)=0
add2(5)=0
add2(6)=1
add2(7)=1
add3(0)=0
add3(1)=0
add3(2)=0
add3(3)=0
add3(4)=1
add3(5)=1
add3(6)=1
add3(7)=1
' initialize variables
let A1_pin = 12
let A2_pin = 13
let A3_pin = 14
let A_EN = 15 ' ENABLE pin on address decoder
let statpin = 4 ' pin to detect digital status
let cycles=90 ' trigger one email soon after startup
timer 5000,[adrloop]
' set address pins to initial state
io(po,A1_pin,0)
io(po,A2_pin,0)
io(po,A3_pin,0)
io(po,A_EN,0)
' create button on webpage
button "end", [getout]
wait
' run through address combinations
[adrloop]
cycles=cycles+1 'increment to trigger email
io(po,0,0) ' use red LED as indicator
for x=0 to 3 ' get Fan status', pressures
io(po,A_EN,0)
io(po,A1_pin,add1(x))
io(po,A2_pin,add2(x))
io(po,A3_pin,add3(x))
delay 100 'let address settle
io(po,A_EN,1) 'turn on ENABLE
delay 100
' get status and pressures
stat(x+1)=io(pi,statpin)
pres(x+1)=io(ai)
next x
io(po,0,1) 'red LED as indicator
io(po,A_EN,0)
io(po,A1_pin,0)
io(po,A2_pin,0)
io(po,A3_pin,0)
io(po,2,1)
romcode = temp() 'uses one-wire on io 2
delay 100
tem1 = (temp("28e0e6dc060000b3")*1.8)+32
tem3 = (temp("28f5eddd060000fc")*1.8)+32
tem2 = (temp("280309dd060000f9")*1.8)+32
tem4 = (temp("2887dadd060000df")*1.8)+32
serialprint "temp1= "
serialprintln tem1
serialprint "temp2= "
serialprintln tem2
serialprint "temp3= "
serialprintln tem3
serialprint "temp4= "
serialprintln tem4
serialprintln " "
serialprintln romcode
serialprint stat(1)
serialprint " "
serialprint stat(2)
serialprint " "
serialprint stat(3)
serialprint " "
serialprintln stat(4)
serialprint pres(1)
serialprint " "
serialprint pres(2)
serialprint " "
serialprint pres(3)
serialprint " "
serialprintln pres(4)
'serialprintln " "
serialprint "Cycles= "
serialprintln cycles
serialprintln " "
if cycles > 100 then
goto [mailcall]
end if
wait
[getout]
[mailcall]
server = "mail.smtp2go.com"
port = "2525"
user = "tom@xxxxxxx.ca"
pw = "xxxxxxxx"
sendto = "yyy@myisp.com"
from = "www@xxxxxx.ca"
subject = "HVAC update"
body3 = "Information about system status apr8/2017"
spc = " "
'let xnum=1234
'let ynum=5678
body1 = str(tem1)
body2 = str(tem2)
body4 = str(pres(1))
body5 = str(pres(2))
body=body1&spc&body2&spc&body4&spc&body5
serialprintln body
setupemail server, port, user, pw
[SendEmail]
email sendto, from, subject, body
cycles = 0
wait
