Question 1, Do I have to use "Let Address=" or can I use "Let i2c_addr" ?
Question 2, Is "Let" lower or upper case? - finding it hard to read the examples.
# Based on github piglow-test.py https://github.com/pimoroni/piglow/blob/master/piglow-test.py
#This section is just mapping the leds. Hex values used until I can convert
#Let LED_Color_Red = 01, 07, 12
#Let LED_Color_Orange = 02, 08, 11
#Let LED_Color_Yellow = 03, 09, 10
#Let LED_Color_Green = 04, 06, 0e
#Let LED_Color_Blue = 0f, 05, 0c
#Let LED_Color_White = 0a, 0b, 1d
#Arms
#Let Arm_0 = 01, 02, 03, 04, 0f, 0d
#Let Arm_1 = 07, 08, 09, 06, 05, 0a,
#Let Arm_2 = 12, 11, 10, 0e, 0c, 0b
# Individual Leds
#Let Led_0 = 01
#Let Led_1 = 02
#Let Led_2 = 03
#Let Led_3 = 04
#Let Led_4 = 05
#Let Led_5 = 06
#Let Led_6 = 07
#Let Led_7 = 08
#Let Led_8 = 09
#Let Led_9 = 10
#Let Led_10 = 11
#Let Led_11 = 12
#Let Led_12 = 0a
#Let Led_13 = 0b
#Let Led_14 =0c
#Let Led_15 =0d
#Let Led_16 =0e
#Let Led_11 =0f
# command register addresses for the SN3218 IC used in PiGlow
Let CMD_ENABLE_OUTPUT = 0
Let CMD_ENABLE_LEDS = 19
Let CMD_SET_PWM_VALUES = 1
Let CMD_UPDATE = 22
# Address of SN318 driver chip
Let i2c_addr = 84
# The code
i2c.begin(i2c_addr)
i2c.write (CMD_ENABLE_OUTPUT, 1) # turn on
i2c.write (CMD_ENABLE_LEDS, [255, 255 255]) # Will this even work?
i2c.write (CMD_SET_PWM_VALUES, values)
i2c.write (CMD_UPDATE, 255)
i2c.end
values = [0x01, 0x02, 0x04, 0x08, 0x10, 0x18, 0x20, 0x30, 0x40, 0x50, 0x60, 0x70, 0x80, 0x90, 0xA0, 0xC0, 0xE0, 0xFF] # Individual let address
updated but not sure on the values.....
I suffer from a bad case of random misfiring synapses!
