if (Name == F("D8")) PinReturnValue = 13;
I think that should be 15, not 13.
Explore... Chat... Share...
forlotto wrote:I wonder if this was an intentional change in the map or something else?
byte LookUpNodeMCUPins(String Name)
byte nodemcuPins[8] = { 16,5,4,0,2,14,12,13,15 };
if (Name.charAt(0) == F("D"))
PinReturnValue = nodemcuPins[Name.charAt(1)-48];
if (Name == F("RX")) PinReturnValue = 3;
if (Name == F("TX")) PinReturnValue = 1;
return PinReturnValue;
}It takes about 20-25 seconds for home assistant c[…]
