Pls show example code to use arrays.
Explore... Chat... Share...
dim bla$(10)
'fill array with stuff
for x = 1 to 10
bla$(x) = str(x) & " is my loop no"
next x
'print stuff from array
for x = 1 to 10
print bla$()
next xIt takes about 20-25 seconds for home assistant c[…]
