Report Bugs Here
By jlbachiochi
#52032 I'm writing an application to display data values that will come from an external device. There is a large number of registers I can ask for. To reduce clutter I've separated them into smaller pieces. Presently I'm only looking for one register in each area. Areas are picked via a 'listbox'. The listbox begins to work incorrectly when I set an array value, I've whittled this program down to the basics that demonstrate this issue.
If this program is run as is it will show the erroneous execution. Remove the rem at line 87 and the program will return before assigning the array value and listbox will operate correctly.
Code: Select all  memclear
  dim reqarray(8)
  baudrate 115200
  serialtimeout 10
  serial2begin 115200, 4 , 5
  choice="Real Time Datum"
  gosub [UpdateData]
[GUI]
  wprint "MQST MPPT Solar Charge Controller 8-3-2016" & "<BR>"
  wprint "  running on ESP Basic Version 3.0a23" & "<BR>" & "<BR>"
  dropdown choice,"Rated Datum,Real Time Datum,Real Time Status,Statistical Parameters,Setting Parameters,Switch  Parameters,Discrete Parameters"
button "refresh",[refresh]
  wprint "<BR>" & htmlvar(choice) & "<BR>" & "<BR>"
  wprint htmlvar(Stat0)
  wprint htmlvar(Stat1)
  wprint htmlvar(Stat2)
  wprint htmlvar(Stat3)
  wprint htmlvar(Stat4)
  wprint htmlvar(Stat5)
  wprint htmlvar(Stat6)
  wprint htmlvar(Stat7)
  wprint htmlvar(Stat8)
  wprint htmlvar(Stat9)
  wprint htmlvar(Stat10)
  wprint htmlvar(Stat11)
  'timer 5000,[TimesUp]
  wait
[refresh]
gosub [UpdateData]
  returngui
  wait
[TimesUp]
  gosub [UpdateData]
  wait
[UpdateData]
  Stat0 = ""
  Stat1 = ""
  Stat2 = ""
  Stat3 = ""
  Stat4 = ""
  Stat5 = ""
  Stat6 = ""
  Stat7 = ""
  Stat8 = ""
  Stat9 = ""
  Stat10 = ""
  Stat11 = ""
  if choice == "Rated Datum" then
    gosub [Rated_Datum]
  end if
  if choice == "Real Time Datum" then
    gosub [Real_Time_Datum]
  end if
  if choice == "Real Time Status" then
    gosub [Real_Time_Status]
  end if
  if choice == "Statistical Parameters" then
    gosub [Statistical_Parameters]
  end if
  if choice == "Setting Parameters" then
    gosub [Setting_Parameters]
  end if
  if choice == "Switch Parameters" then
    gosub [Switch_Parameters]
  end if
  if choice == "Discrete Parameters" then
    gosub [Discrete_Parameters]
  end if
  return
[request]
  response="Time Out!"
  'return
  reqarray(0)=1
  return
  reqarray(1)=4
  MSB=int(address/256)
  LSB=address-(MSB*256)
  reqarray(2)=MSB
  reqarray(3)=LSB
  MSB=int(count/256)
  LSB=count-(MSB*256)
  reqarray(4)=MSB
  reqarray(5)=LSB
  response="Timeout!"
  return
[Rated_Datum]
  address=12288 ' 0x3000
  count=1
  gosub [request]
  ARV=response
  Stat0 = "Array Rated Voltage = " & ARV & " Volts" & "<BR>"
return
[Real_Time_Datum]
  address=12544 ' 0x3100
  count=1
  gosub [request]
  PVAIV=response
  Stat0 = "PV Array Input Voltage = " & PVAIV & " Volts" & "<BR>"
  return
[Real_Time_Status]
  address=12800 ' 0x3200
  count=1
  gosub [request]
  BS=response
  Stat0 = "Battery Status = " & BS & " Volts" & "<BR>"
return
  address=13056 ' 0x3300
  count=1
  gosub [request]
  MPVVT=response
  Stat0 = "Maximum PV Voltage Today = " & MPVVT & " Volts" & "<BR>"
return
  address=36864 ' 0x9000
  count=1
  gosub [request]
  BT=response
  Stat0 = "Battery Type = " & BT & "<BR>"
return
[Switch_Parameters]
  address=0 ' 0x0000
  count=1
  gosub [request]
  CDS=response
  Stat0 = "Charging Device Status = " & CDS  & "C" & "<BR>"
return
  address=8192 ' 0x2000
  count=1
  gosub [request]
  OTD=response
  Stat0 = "Over Temperature (Device) = " & OTD  & "C" & "<BR>"
return
By Mmiscool
#52070 Just posted a new build that should resolve this problem.
It was related to the selection of the variable for the drop down. Unrelated to arrays.
Download the latest build.
By forlotto
#52073 Could you post your project when you get it finished up I simply love solar projects and reading about alt energy stuff. Very interesting and useful.
Project Pictures, video, explanation, code, hardware brief description of what you are doing etc...
This would be great remember the old saying share and share alike like it or not it really does apply to real life ;)
Thanks!
