instr$ = ""
do
do
if serial.available() > 0 then instr$ = instr$ & serial.read.chr()
loop until right(instr$,1) = chr(13)
if left(instr$, 1) = "*" then
serialflush
instr$ = left(instr$, len(instr$) - 1)
end if
gosub [strtohex]
print "Value = " & str(rval)
loop while rval <> 1
[strtohex]
rval = 0
if left(instr$, 2) = "0x" then instr$ = mid(instr$, 3, 99)
instr$ = upper(instr$)
for i = 1 to len(instr$)
t = asc(mid(instr$, i, 1))
if t > 57 then
t = t - 55
t = t - 48
end if
rval = rval * 16 + t
next i
instr$ = ""
return
No, it's not the neatest but, like I say, it was an exercise to test various functions.
Anyway, all seemed to go well; put in FABC and get 64188. Put in FABCD and get 1027021.
Put in FABCDEF and get 262917616 - oops! That should be 262917615.
Problem is, put in anything between FABCDE9 and FABCDEF and you get the same result. Put in anything between FABCDE0 and FABCDE8 and you get 262917600 for each.
Because I thought my logic might be screwy I put in the line
print "HexToInt gives " & hextoint(instr$)Now, maybe there's a limit on integer values that was unaware of, but in this case, why did the answer 'flip up' by 16 at the 8/9 point?
Anyone got any thoughts?
Phil
