V3 Flasher never Formats
Posted: Sun Sep 25, 2016 5:41 am
I have a very predictable and repeatable bug with V3.
The first time of trying to 'save' after wifi connection will invariably succeed.
But the second time of trying to 'save' will always cause an esp crash and reboot.
Retry the 'save' after allowing time for reconnection again and it will succeed, but edit and try to save changes again will cause another crash and reboot.
It happens every other time after connection!
I should add that this may be something to do with the fact that I have never been successful in doing a V3 Format Flash - which always pops up a window saying...
'esptool.exe has stopped working.'
'A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.'
The only option then is to click the big 'Close program' button and close everything down.
If I reboot the esp device back into reflash mode, then just go for a Firmware Flash without a Format, it succeeds ok. Everything then appears to work, except as mentioned above, where every other 'save' causes an esp disconnect and reconnect.
I should point out that this only applies to the V3 Flasher (and all versions which I've tried), whereas if I use the V2 A24 Flasher afterwards it Formats ok every time.
I should also point out that the V3 Format failure occurs with every device I've tried, including nodeMCU, but they can all be V3 Flashed ok.
Are these 2 problems related?
Is there any solution for them?
