LOCK CODE - LOST CODE SOMETIMES ?
PostPosted: Fri Oct 21, 2016 6:26 pm
by tcpipchip
Is it possible lock the source code ?
sometimes when i try to edit the code and a TCP/UP application is running, destroy the part of source code....
TCPIPCHIP
Re: LOCK CODE - LOST CODE SOMETIMES ?
PostPosted: Mon Oct 31, 2016 5:05 pm
by tcpipchip
I know that is not the right way, but for me, i changed the code to block access to EDIT when the basic code is running!
The same i did to the DEBUG option
PostPosted: Mon Oct 31, 2016 8:11 pm
by russm
Also more work but I keep a second copy of the code in a backup file on the esp and if really important I also keep one in notepad. You can frequently hit the back button and the browser will have your code if you forget. Done this a few times. Usually quite lucky that way. Sounds like a Clint Eastwood line from Unforgiven... :D
