Report Bugs Here
By tecnihouse
#58196 I am trying to use the command graphics of the example and throws me the following error:
Error at line 2: Failed to reach end of input expression, likely malformed input
Error at line 2: Syntax error
Error at line 2: Halted
Code:
memclear
graphics 300,300
timer 1000, [doit]
[top]
x = 0
gcls
text 10,100,"Anolog in",180 + 90
text 100, 250, "Time (1 second)",0
wait
[doit]
aOLD = a
a = io(ai) / 4
xOLD = x
x = x + 10
line xOLD,aOLD,x,a,5
if x > 300 then goto [top]
wait
Also tested this other syntax but the same gives me error in line 3
memclear
graphics
300 300
timer 1000, [doit]
What can it be?
Thank you very much for your help
By bugs
#58203 What version of BASIC are you using?
Yor first code is correct - I pasted it into a nodemcu using ESP Basic 3.0.Alpha 57.
There was a screen with "Analog in" up the left hand side, "Time (1 second)" along the x axis and a horizontal line being slowly drawn along the top of the screen.
By Electroguard
#58205 Hi tecnihouse,
You can find an updated clock with correct syntax on mmiscool examples page here:
https://www.esp8266basic.com/graphic-clock-example.html
But at the heart of the clock is the time() function, and when I include this test line at the top of my scriptL
Code: Select allprint time()
it returns...
Thu Jan 01 00:00:00 1970 for me,
Perhaps that is the back to defaults ESP device time, but it may come as a disappointment if you are to see your computer clocks time.
By tecnihouse
#58207 Electroguard:
I have tried to put the code of your link https://www.esp8266basic.com/graphic-clock-example.html
Code: Select all​timer 10000, [drawClock]
print "Graphic Clock"
print
graphics 500, 500
And the link http://www.esp8266.com/viewtopic.php?f=40&t=6995
Code: Select allprint "Graphic Clock"
print
graphics 500 500
gcls
gosub [drawhour]
gosub [drawminute]
Always same error "Failed to reach end of input expression, likely malformed input" , "Syntax error"
I have tried in chrome Version 54.0.2840.99 m and Firefox 49.0.2.
I hope some other advice or suggestion this is driving me crazy
Thanks.
PD:
It works for me return :
"Wed Nov 16 12:34:20 2016"
