Page 1 of 3
IR.RECV.XXX Errors.
PostPosted: Wed Jan 11, 2017 10:10 am
by dom53284
Hi.
First, thank you for this fantastic project. Incredibly easy. :D
Next, i have been playing with the ir.recv.xxxx() function.
I use two of the cheap $ 1 remote from eBay, and a YS-IRTM Modul, to compare the output.
I have made this code:
Code: Select allir.recv.setup(2)
irbranch [ir_input]
wait
[ir_input]
let s = ir.recv.full()
print s
return
When i press the "OK"-button i get from YS-IRTM: (I guess that it supress the inverse command).
00FF40
From ESP i get:
d7e84b1b:UNKNOWN:32
And if i hold the button:
d7e84b1b:UNKNOWN:32
ffffffff:NEC:0
ffffffff:NEC:0
ffffffff:NEC:0
ffffffff:NEC:0
If i press the "2"-button then from the YS-IRTM i get:
00FF18
but from ESP:
3d9ae3f7:UNKNOWN:32
I believe, that the address from the sender should be equal from all buttons, just as they are from YS-IRTM. ?
If i change the code to ir.recv.dump(), then from the "OK"-button:
Unknown encoding: D7E84B1B (32 bits)
Raw (68): 8950 -4550 550 -650 550 -650 550 -650 550 -650 550 -650 550 -650 550 -650 550 -650 550 -1700 550 -1700 550 -1700 550 -1700 550 -1700 550 -1750 550 -1700 550 -1700 550 -650 550 -650 550 -650 550 -650 550 -650 550 -650 550 -1700 550 -650 550 -1700 550 -1700 550 -1700 550 -1700 550 -1700 550 -1700 550 -650 550 -1700 550
d7e84b1b
Looking at the Raw, i think it looks prette close to the output from YS.IRTM, and NEC-specs :?:
Any idea, what is wrong?
And what is the chance that there will be a ir.send.raw () function in the near future?
I plan to make a project like https://github.com/ToniA/arduino-heatpumpir but would like to get rid of the Arduino. :lol:
Re: IR.RECV.XXX Errors.
PostPosted: Thu Jan 12, 2017 5:23 am
by bugs
Hi,
Are you using the lastest version 3 BASIC?
I did have similar problem some months ago when the decoding done by the library produced the wrong code, as it was missing the first data bit.
I have just tried your simple code on a nodemcu with an IR detector and the correct code is shown from an NEC remote (although leading zeros are suppressed).
eg remote sends NEC 01FC6897 and the printed output is:-
1fc6897:NEC:32
ffffffff:NEC:0
ffffffff:NEC:0
The fffffff is returned by the library when the last key is repeated.
PostPosted: Thu Jan 12, 2017 5:51 am
by dom53284
Hi.
Yes!
ESP Basic 3.0.Alpha 65
I use an ESP-01, but waiting for a Nodemcu in the snailmail from China :roll:
PostPosted: Thu Jan 12, 2017 1:11 pm
by bugs
The decoded hex strings are obviously wrong as there are no complements - but the raw received codes look reasonable and can be decoded by hand - so the fault is in the software decode.
Just for interest - what IR receiver are you using with ESP and what supply voltage and resistor?
I found that some did not give good signals at 3.3 volt - but as your raw looks ok I don't think that is the problem.
I may be able to try an ESP-01 tomorrow.
