Array or slider bug
Posted: Sat Mar 18, 2017 8:35 am
Hi there,
For testing purposes for a specific project i need multiple sliders.
So I thought to be clever and made an array with 7 elements.
Next I put some sliders on the screen and used the array entries as slider value.
Not working.
This snippet does not put the slider value into the array.
Look at the following code:
If I change the variable in a normal variable like test1 and test2 the code works flawlessly.
So is the bug in the array function or in the slider function......
I can bypass this by using individual variables for the sliders. However If I need many sliders I am running against the varaiable limit of ESP-Basic, so using sliders with an array would be nice. Besides that I would like about 12 sliders (maybe more) and an array would make programming that a lot easier.
Luc
Not working.
slider testval(1), 0, 255
dim testval(6)
for x = 0 to 5
testval(x) = 0
next x
wprint "<br>"
wprint "<br>"
slider testval(2), 0, 255
wprint "<br>"
wprint "<br>"
button "Change", [change]
wait
[change]
for x=0 to 5
wprint testval(x)
wprint "<br>"
next x
wait
Luc
