One of the recurring problems with the syntax relates to spaces - and whether they should be there or not.
Earlier threads have already pointed out that the space in front of an "=" sign is essential. The space following, however, is not.
Yesterday I was working with file read and write, and it didn't want to play. After some frustration, it seems that write ({filename}, [data$}) does NOT work - however, write({filename}, [data$}) works fine. In other words, in this case you must NOT put a space before the opening parenthesis.
I seem to remember reading about another command recently where it was stated that a space must not be present. All this is very confusing.
I certainly don't have the necessary knowledge to write a compiler, but I have had to implement parsing in many programs in the past. One of the earliest stages was always to remove ALL spaces, except those occurring between quotes - ie strings. That way, whether a space was present or not was irrelevant.
If this is impracticable, then could we at least have some consistency? - either we ALWAYS need a space separating parts of a command or function, or we NEVER need a space in there. This would save me a lot of time!
Phil
