Report Bugs Here
By Alberto_2
#73499 To display the celsius abbreviasion I use chr(32) & chr(176) & chr(67). The ascii sequence is loaded into a variable (dgr) and then the same variable is used with the oledprint command.
When I save the program the variable dgr get corrupted into chr(195) & chr(195) & chr(67). If I do remove the space (chr(32)) then the variable wiil not be corrupted and the oledprint is also correct ( without the space obviously)
Using version 3.0 alpha
Edited:
Also without any spaces, when I load the program using "EDIT" the character chr(195) is automaticaly inserted in front of chr(176). I need to remove chr(195) manualy, before to save the code again to have the corrected print out.
