Report Bugs Here
By sandfrog
#34575 Hello, i Connekt the ESP to my router and this works Fine, the ESP not close the AP Mode ? and i can not change the settings on SSID and PW its not Work, i tree the 1.04 an 1.47 is same issue.
I have the ESP -07 Board i flash with the 512k Settings is that Corekt ?
Sorry for my Bad Englisch
By Mmiscool
#34584 I don't know the flash size on an esp-07.
Try going to the setting page and formatting the device with the format button.
This might correct your issues.
512k option has a very limited program size. You could try 1m and see if that works for you.
By Mmiscool
#34585 Also you must restart after putting in new wifi settings. Mabe try that first and see what happens.
DO you have the device hooked up to a serial terminal at 9600 baud?
By sandfrog
#34590 Hello,
THX for help
I have set "Format" in the "Settings" and set in new,the ESP Conect to the AP in Clientmode, chages on the AP Mode not Work.
I test Flash the Firmware 1M and 512k i see not I see no changes, the others not Work.
The Log from UART:
Code: Select allConnected to DasLebenIstKeinPonnyhof-K
IP address : 192.168.0.33
WIFIname
WIFIpass
WIFIname
WIFIpass
APname
APpass
LoginKey
ShowMenueBar
Starting Default Program
Done...
Formating
1WIFIname
WIFIpass
APname
APpass
LoginKey
ShowMenueBar
2dO�4��$ z�4B8�ESP Basic 1.47
1
2
3
4
WIFIname
WIFIpass
Done...
