Example...
msg = "This is a test"
print right(msg,6)
returns "a test"
Explore... Chat... Share...
msg = "this_is_a_long_string_to_test"
short = left(msg,6)
print short
short = right(msg,6)
print short
short = mid(msg,6,3)
print short
short = mid(msg,6)
print short
print "All done!"
waitthis_i
o_test
is_
All done!TassyJim wrote:right(msg,x) gives you the righmost x characters
cwilt wrote:If that is the way it should work then the documentation is wrong.
short = mid(msg,6,99)
print shortIt takes about 20-25 seconds for home assistant c[…]
