The Accel version would be nice but even the standard arduino version would be fine.
Regards,
Jim
Explore... Chat... Share...
[moveMotor]
' Variables you meed to set:
' ID - stepper motor id, 0 to 7
' DIRECTION - 1 = forward, 0 = reverse
' STEPS - Number of steps to go
' STEPDELAY - milliseconds to delay between steps
' Start by setting multiplexers to address the correct stepper motor driver
if id>3 then io(po,14,1) else io(po,14,0)
if (id and 2) >0 then io(po,13,1) else io(po,13,0)
if (id and 1) >0 then io(po,12,1) else io(po,12,0)
' Set direction
io(po,4,direction)
' Perform all requested steps
for stepcount=1 to steps
io(po,5,1)
io(po,5,0)
delay stepdelay
next stepcounter
returnIt takes about 20-25 seconds for home assistant c[…]
