I believe it may execute faster than a series of if-then loops and wouldn't be as hard on the stack - if the stack is even a concern.
Thanks for all you do, This Buds for you, Bud!
- Albert Einstein
Explore... Chat... Share...
goto [place]goto "[place]"let destination="[place]"
goto destinationdim destination(10)
let destination(5)="[place]"
goto destination(5)let destinations="[po] [pwo] [servo] [pi] [pwi] [ai] [temp]"
' Magical code happens here which encounters a device on pin P performing function FNC with state S (for outputs)
let place=word(destinations,fnc)
gosub place
' Code continues with return value in RV set by called routine
wait
[po]
io(po,p,s)
return
[pi]
rv = io(pi,p)
return
[ai]
rv = io(ai)
return
' Etc, etc.It takes about 20-25 seconds for home assistant c[…]
