I would like to be able to use Blynk with projects built with ESP BASIC, and although I had a look through the Blynk source code files ( https://github.com/blynkkk/blynk-librar ... tag/v0.4.3 ), I'm at a loss as to how I could convert these to be able to use them.
I thought I might have to go back to using the Arduino IDE and program the ESP the old fashioned way
My projects usually require a few ESP's to be located outside the premises or in the garage, and the simplicity of being able to just log into these from anywhere and change or adjust the code is a godsend
I looked into using the Arduino IDE option of OTA updates as possible solution, but compared to the way ESP BASIC works, it seems a bit long winded, requiring several extra lines of code and the need for the program to constantly check for an OTA update within the "loop", whereas ESP BASIC makes things so easy and makes utilizing and updating a project very quick and simple (or as simple as you want it, as ESP BASIC can also do some complicated stuff, but it even makes that easy, thanks to MM and the thought that's gone into it).
I have now resigned myself to continuing to use ESP BASIC for everything ESP I do, as the usability and flexibility of it is amazing, and MM deserves a medal for the hard work that has obviously gone into it (and I haven't even mentioned the "on the fly" VAR's and DEBUG options, which take the stress out of finding any errors).
The only thing I miss is being able to use the Blynk app on my phone to control everything, and although I could use the MIT app inventor to build a basic app, Blynk seems to offer a more professional and streamlined look and feel, and to be able to use this with ESP BASIC projects would make it perfect ...and make me a very happy boy
edit... after looking into BLYNK I see that it relies on an external cloud server as a middleman, that is a bit disappointing. I have already worked with the ElectricIMP module and did not like the fact that it required an external server to make my projects function.
dwight
Details at: http://docs.blynk.cc/#blynk-server
Although I imagine using their own servers is no bad thing, being able to run your own Blynk server and have ultimate control over everything makes it an even more attractive option
