Having trouble seeing how to integrate several snippet examples into a larger program.
Explore... Chat... Share...
wget "http://172.16.0.184/msg?pin=2&stat=1&action=po" -q -O -msgbranch [mybranch]
print "You can send msgs to the esp and do things based on accessing a URL"
wait
[mybranch]
MyReturnMsg = "Not a valid msg received"
msgget "pin" pinNo
msgget "stat" pinStatus
msgget "action" pinAction
if pinAction == "po" then gosub [po.pin]
if pinAction == "pi" then gosub [pi.pin]
if pinAction == "pwo" then gosub [pwo.pin]
if pinAction == "pwi" then gosub [pwi.pin]
if pinAction == "ai" then gosub [ai.pin]
print "DOne with retrn code"
msgreturn MyReturnMsg
wait
[po.pin]
po pinNo pinStatus
MyReturnMsg = "good"
return
[pi.pin]
pi pinNo MyReturnMsg
return
[pwo.pin]
pwo pinNo pinStatus
return
[pi.pin]
pwi pinNo MyReturnMsg
return
[ai.pin]
ai MyReturnMsg
return
