By sadat007
#37864 I like to have feature like more than one settings pages available instead of just one so I can select setting-1, setting-2 or setting-3 etc with the help of on push button during boot-up. Use the default LED (wifi data or connection LED) with blinking sequences ..... This will also make possibility of reset to default....
Thanks dear
By sadat007
#37871
td_setting_menu.jpg[/attachment]
For example I can save router setting for home in settings-1 and office router in settings-2 and in settings-3 I like to put unsecured AP.... also like to have default program for each..
Thanks dear
By forlotto
#37942 hrmmm... Not a bad idea ...
You could add it to your code ...
scan for signal of each ssid
connect to one with strongest signal
If I am not mistaken wifi signal command was added....
Just a thought although I do like your idea it would be best likely personalized within your code rather than the interface as the interface is somewhat quirky broadcasting the AP mode at times if you disconnect your router so you may want to try the route of adding it to your code possibly just a suggestion but by all means don't let me discourage you my two cents is worthless as I don't fully understand your device nor your needs specifically without you sharing more information as to what is the device you will be using this for?
VISIT HERE TO FIGURE OUT HOW: viewtopic.php?f=43&t=7210#p37801
