For those of you folks who really need OTA updates for the latest firmware I have setup a secondary update server for the time being.
Just add this info to the OTA box
esp8266basicota.tk/4M/ESP8266Basic.cpp.bin Then save settings
Then hit update.
I have v34 on there currently I may not get everything instantly or I may even miss a build or two but I will check back and update it periodically.
I know this works on nodemcu 4MB flash versions does it work on other smaller flashes or versions I am not sure to be honest have not tested this but their are folders for each version on the server just copy the link and give it a try and report back remember do not use the http:// in front of the link when pasting the link delete this portion.
I have tested it and has worked accurately for the last 6 builds roughly.
May be of use to someone may not who knows I found it rather useful myself so I figured I would share.
How will I know it has worked you say?
How you will know it works is once you click the update button there will be some time that will pass when trying to load the page and it will go offline and reset the unit once it comes back up you can visit the settings page and take note of how the version number has changed.
Enjoy
-forlotto
Where I buy my ESP8266 boards from... (Banggood)
