First of all my congratulations to MMISCOOL for the great work on ESP8266 Basic.
I need some help in rebuild the source code,. I only want to translate change some strings, to be on my language.
I'm not very good at C but I think I can manage.
So, after install the latest versio of Arduino (1.6.11) I had the ESP8266 boards installed using this tutorial:
https://learn.sparkfun.com/tutorials/es ... uino-addon
Then I downloaded the ESPbasic source code from the GitHub and replace the libraries of Arduino with the ones in the source code.
Choose "Generic ESP8266 module as board"
Open "ESP8266Basic.ino" and try to rebuild without any modification on the source code.
Got a lot of errors
Build options changed, rebuilding all
In file included from D:\Arduino\Basic_ESP8266\ESP8266Basic\ESP8266Basic.ino:767:0:
sketch\Classes.h: In member function 'void JUMPLIST::add(String, uint16_t)':
Classes.h:100: error: 'PrintAndWebOut' was not declared in this scope
PrintAndWebOut(String(_ERR4) + label); // label already defined
Classes.h:105: error: 'PrintAndWebOut' was not declared in this scope
PrintAndWebOut(String(_ERR7) + label); // too much labels
sketch\Classes.h: In member function 'void IFBLOCKLIST::setIf(uint16_t)':
Classes.h:222: error: 'PrintAndWebOut' was not declared in this scope
PrintAndWebOut(String(_ERR5) + String(stack[_ptr]._ifpos)); // too much if endif nested
and so on...
What I'm doing wrong?
Thanks for any help
Joaquim
