Notepad++ Styler
Posted: Mon Jun 05, 2017 7:19 am
I created a style definition for esp8266Basic for Notepad++ I thought I'd post it just in case someone else might find it useful. You can save the code below as an XML file and import it under "Language>Define Your Language".
<NotepadPlus>
<UserLang name="espBasic" ext="bas" udlVersion="2.1">
<Settings>
<Global caseIgnored="yes" allowFoldOfComments="no" foldCompact="no" forcePureLC="0" decimalSeparator="0" />
<Prefix Keywords1="no" Keywords2="no" Keywords3="no" Keywords4="no" Keywords5="no" Keywords6="no" Keywords7="no" Keywords8="no" />
</Settings>
<KeywordLists>
<Keywords name="Comments">00' 01 02 03 04</Keywords>
<Keywords name="Numbers, prefix1"></Keywords>
<Keywords name="Numbers, prefix2"></Keywords>
<Keywords name="Numbers, extras1"></Keywords>
<Keywords name="Numbers, extras2"></Keywords>
<Keywords name="Numbers, suffix1"></Keywords>
<Keywords name="Numbers, suffix2"></Keywords>
<Keywords name="Numbers, range"></Keywords>
<Keywords name="Operators1">[]()</Keywords>
<Keywords name="Operators2">= == + _ * / ^ & % > <</Keywords>
<Keywords name="Folders in code1, open"></Keywords>
<Keywords name="Folders in code1, middle"></Keywords>
<Keywords name="Folders in code1, close"></Keywords>
<Keywords name="Folders in code2, open"></Keywords>
<Keywords name="Folders in code2, middle"></Keywords>
<Keywords name="Folders in code2, close"></Keywords>
<Keywords name="Folders in comment, open"></Keywords>
<Keywords name="Folders in comment, middle"></Keywords>
<Keywords name="Folders in comment, close"></Keywords>
<Keywords name="Keywords1">IF
THEN
DO
LOOP
FOR
NEXT
End If</Keywords>
<Keywords name="Keywords2">CLS
WPRINT
WPRINT
BUTTON
IMAGEBUTTON
TEXTBOX
PASSWORDBOX
SLIDER
DROPDOWN
LISTBOX
METER
ONLOAD
WAIT
RETURNGUI
HTMLID
GUIOFF
GUION
CSSID
CSSCLASS
JAVASCRIPT
CSS
JSCALL
wget
ip
Udpbegin
Udpstop
UdpbeginMultiCast
Udpwrite
UdpwriteMultiCast
UdpReply
UdpRead
UdpRemote
UdpBranch
msgReturn</Keywords>
<Keywords name="Keywords3">GOTO
GOSUB
RETURN</Keywords>
<Keywords name="Keywords4">io
TEMP
delay
GPIO1RESET
interrupt
timer</Keywords>
<Keywords name="Keywords5">len
instr
instrrev
mid
left
right
trim
str
replace
chr
asc
upper
lower
id
version
word
json
ReadOpenWeather</Keywords>
<Keywords name="Keywords6">sqr
sin
cos
tan
log
rnd
millis
int
val
oct
hex
hextoint
ramfree
flashfree
pow
exp
asin
acos
atan
atan2
abs
fabs
floor
ceil
round</Keywords>
<Keywords name="Keywords7"></Keywords>
<Keywords name="Keywords8"></Keywords>
<Keywords name="Delimiters">00 00[ 01 02 02] 03 04 05 06( 07 08) 09 10 11 12" 13 14" 15 16 17 18 19 20 21 22 23</Keywords>
</KeywordLists>
<Styles>
<WordsStyle name="DEFAULT" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="COMMENTS" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="LINE COMMENTS" fgColor="008000" bgColor="FFFFFF" fontName="" fontStyle="2" nesting="0" />
<WordsStyle name="NUMBERS" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="KEYWORDS1" fgColor="000080" bgColor="FFFFFF" fontName="" fontStyle="1" nesting="0" />
<WordsStyle name="KEYWORDS2" fgColor="4043BF" bgColor="FFFFFF" fontName="" fontStyle="3" nesting="0" />
<WordsStyle name="KEYWORDS3" fgColor="0000FF" bgColor="FFFFFF" fontName="" fontStyle="1" nesting="0" />
<WordsStyle name="KEYWORDS4" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="1" nesting="0" />
<WordsStyle name="KEYWORDS5" fgColor="1B6065" bgColor="FFFFFF" fontName="" fontStyle="1" nesting="0" />
<WordsStyle name="KEYWORDS6" fgColor="0000FF" bgColor="FFFFFF" fontName="" fontStyle="3" nesting="0" />
<WordsStyle name="KEYWORDS7" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="KEYWORDS8" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="OPERATORS" fgColor="FF00FF" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="FOLDER IN CODE1" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="FOLDER IN CODE2" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="FOLDER IN COMMENT" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="DELIMITERS1" fgColor="0080FF" bgColor="FFFFFF" fontName="" fontStyle="1" nesting="0" />
<WordsStyle name="DELIMITERS2" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="DELIMITERS3" fgColor="400080" bgColor="FFFFFF" fontName="" fontStyle="1" nesting="0" />
<WordsStyle name="DELIMITERS4" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="DELIMITERS5" fgColor="FF8000" bgColor="FFFFFF" fontName="" fontStyle="2" nesting="0" />
<WordsStyle name="DELIMITERS6" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="DELIMITERS7" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
<WordsStyle name="DELIMITERS8" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
</Styles>
</UserLang>
</NotepadPlus>
