#include "indexl.h"
const char* ssid = " ";
const char* password = " ";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
int dac = 0;
int DigitalPin[] = {4, 12, 13};
int DacPin = 5;
// Auxiliary variables to store selected mode and settings
int selectedMode = 0;
int timer = 0;
int ldrThreshold = 0;
int armMotion = 0;
int armLdr = 0;
String modes[4] = { "Manual", "Auto PIR", "Auto LDR", "Auto PIR and LDR" };
// Decode HTTP GET value
String valueString = "0";
int pos1 = 0;
int pos2 = 0;
// Variable to store the HTTP request
String header;
// Set web server port number to 80
delay(10);
pinMode(4,INPUT);
pinMode(4, INPUT_PULLUP);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
if (!client) {
return;
Serial.println("new client");
while(!client.available()){
delay(1);
String command1 = client.readStringUntil('/');
String command = client.readStringUntil('/');
Serial.println(command1);
Serial.println(command);
client.println("<body><h1>ESP8266 Web Server</h1>");
// Drop down menu to select mode
client.println("<p><strong>Mode selected:</strong> " + modes[selectedMode] + "</p>");
client.println("<select id=\"mySelect\" onchange=\"setMode(this.value)\">");
client.println("<option>Change mode");
client.println("<option value=\"0\">Manual");
client.println("<option value=\"1\">Auto PIR");
client.println("<option value=\"2\">Auto LDR");
client.println("<option value=\"3\">Auto PIR and LDR</select>");
if (command == "digital") {
int pin, value;
pin = client.parseInt();
Serial.println(pin);
if (client.read() == '/') {
value = client.parseInt();
digitalWrite(pin, value);
else {
value = digitalRead(pin);
client.print(F("digital,"));
client.print(pin);
client.print(F(","));
client.println(value);
else if (command == "dac"){
int pin, value;
dac = value;
analogWrite(pin, value);
else {
value = dac;
client.print(F("dac,"));
client.print(pin);
else if (command == "status") {
int pin, value;
client.print(F("status"));
for (int thisPin = 0; thisPin < 3; thisPin++) {
pin = DigitalPin[thisPin];
client.print(F("#"));
client.print(pin);
client.print(F("="));
client.print(value);
pin = DacPin;
value = dac;
client.print(pin);
value = analogRead(A0);
float lux=value;
client.print(F("#A0"));
client.print(lux);
client.println("");
else { // Prepare the response
String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
s += file1;
client.flush();
// Send the response to the client
while(s.length()>2000)
String dummy = s.substring(0,2000);
client.print(dummy);
s.replace(dummy," ");
client.print(s);
delay(1);
Serial.println("Client disconnected");
// The client will actually be disconnected
// when the function returns and 'client' object is destroyed
}Moderator: Mmiscool
I hope you've already been successful in sorting this, but if not it would perhaps be better to post it in an area of the forum that deals with programs written in c++. This section is for esp8266basic (which is a lot easier to work with if you're new to programming!).
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");with something minimal like
Serial.println(WiFi.softAPConfig("192.168.4.22", "192.168.4.9", "255.255.255.0") ? "Ready" : "Failed!");
Serial.println(WiFi.softAP("your_ssid","your_pass") ? "Ready" : "Failed!");
