High Level ESP BASIC Implementation Inquiries
Posted: Mon Mar 18, 2019 12:32 am
Good day. New to ESPs as a whole. Am working embedded dev on some ARM devices, using a BASIC dialect known as ARMbasic (https://www.coridium.us/coridium/). Wanted to add IP and Web Connectivity to my devices (working with 54005 & 54102 uC from NXP currently). Given I am dev'g in ARMbasic, I searched around the interwebz to find what firmware options exist, for the various ESP devices I've settled on (ESP8266 for non-BT/non-BLE stuffs, and ESP-WROOM-32s for those projects that have BT/BLE connectivity requirements), and stumbled upon ESP BASIC. Pretty darned convenient, as I am not a C/C++/OOP guy. Was initially concerned about the maturity, but I see that Mike and the community have invested a lot of effort to get a pretty robust product instantiated in a relatively short period of time. Kudos.!.
Anyways, on to my observations/questions:
EDIT (another question): Is support for ESP BASIC on the ESP-32 family of devices planned?
Please advise. Thank you, in advance!
-MHz
- I see there are branch labels that I perceive are synonymous with sub routines/labels from other BASIC dialects. Are there constructs that a dev can use to implement user functions with - i.e. code blocks that receive passed parameters and return a value (or a pointer to a structure of values)? I understand that globals can be leveraged to return values from a branch label code block. This is more for my situational awareness.
- Does the concept of variable scope exist in ESP BASIC? Again, for my situational awareness.
- I noted the operator table in the docs package. I note the use of $ in string var names is supported but not required (if using the 'as string' hint when a string var w/o a $ is DIM'd).
- Do string functions terminate when a null byte (0x00) is encountered?
- I note the stack depth of 255 for nesting code execution. Are the length of strings or arrays limited?
- Does ESP BASIC's expression parser/syntax support non-base 10 numbers - i.e. Hex representations?
- If so, are same denoted with 0x or &H prefixes?
- Given the interpreted nature of ESP BASIC, I understand this lends a lot of latitude for what is done under the hood vs. what is exposed to those dev'g with ESP BASIC. Is it a correct presumption that there is a distinction between integers and floats in variables, or is everything handled internally as a string and the firmware/runtime deal with those dynamics on a function by function basis?
- Does ESP BASIC employ the use of 32-bit IEEE-754 floats, or is a higher precision float lib being used.
- I note that on the serial port of the ESP-01, when the ESP BASIC interpreter is running, that I observe some traffic from the interpreter (as it might be a bit chatty?). Does the interpreter provide a means to squelch those debug/error emissions and have a user BASIC app have full control over the serial transmissions and receive all serial input from an external device connected thereto?
- Given my intended use of the ESP devices in this context, objectively, is ESP BASIC a viable candidate for the firmware on a device that is going to act in the capacity of a comms transport provider, and possibly as a web UI front-end (if it can serve UI Pages that I interpret it can from the docs)?
-MHz
