By joey
#35333 Hi, thank you for giving iot to the people...
I have problem with loading the user interface.
Wifi connect is OK (at 192.168.4.1)
I get this from terminal program:
Failed Wifi Connect
Creating WIFI access point
ESP
APname
APpass
Starting Default Program
in>
If I flash with 512k, I get "done" from terminal program, and can access the user interface.
But then I cannot save files og run program, because the flash size is wrong.
If I flash back to right flash size, I get same problem.
Is there a way to clear the flash/program or boot without "starting default program"
Do you have a way to set timeout and "end" in the basic program, so it don't get stuck?
Joey
By heckler
#35350 which module are you using?
If ESP8266-01 then is it blue or black pcb? (although it sounds like you have a different module by the terminal responses)
the default program is called "default" but I believe it only exists if you have uploaded code to the module without giving it a name.
By joey
#35355 I'm using esp-12e dev board from doit.
ref: http://www.dx.com/p/404647
It looks like the basic program is running and waiting for input:
in>
I tested "hello world" with "end", that was working:
done
I looks like the user interface is stuck, if I don't have "end" in the program.
Now I'm down to my last module....... =:-(
By Mmiscool
#35382 Hello. I am glad to hear you are using esp8266 basic.
If you saved a program with an input command you will have a > symbol showing on the serial terminal. Send a carage return line feed on the serial terminal and it will continue. The input command is blocking.
Also if you save a blank program before the default program starts it should solve your issue. It will automatically run the default program 30 seconds after boot up.
The esp-12 has a 4 meg flash so you should also reflash the moduel to take advantage of the full storage space available.
