Page 1 of 2
ESP8266-12-f documentation
PostPosted: Tue Apr 12, 2016 8:40 am
by Seetharaman
Hi,
I bought this pretty cheap ESP8266 Ai-Thinker Module onlline. In the module it is written ESP8266MOD and on the backside ESP-12-F.
However, I'm unable to find pinout,datasheets, at commands and getting started guide for this module, which are very different for different versions of this module.
Where do I get these documents?
I'm pretty new to this chip and ESP8266 docs seems to be different for AI thinker modules.
Thanks
Re: ESP8266-12-f documentation
PostPosted: Tue Apr 12, 2016 4:58 pm
by markusonfire
Hi,
The pinout for the 12F should be exactly the same as the 12E (See diagram below) I think the antenna is the only difference between the E and the F.
Brief-spec for the 12E can be found here.
AT commands should be the same for all ESP8266-based boards.
PostPosted: Tue Apr 12, 2016 7:35 pm
by martinayotte
Yes ! the main difference between ESP12E and ESP12F is the antenna and the correction to silkscreen mistake of GPIO4/GPIO5 swapping.
PostPosted: Wed Apr 13, 2016 2:12 pm
by Seetharaman
martinayotte wrote:Yes ! the main difference between ESP12E and ESP12F is the antenna and the correction to silkscreen mistake of GPIO4/GPIO5 swapping.
Can you point me to documents that have Detailed description of the module in English.
Thanks
