Chat freely about anything...
By picstart1
#2085 So far almost all tools have a quirkiness and dependencies.
The dependence on the initial pin configuration at power up of the esp8266 is expected
Next there is the OS you are using linux and windows.
XTCOM always messes up my Windows & pc requiring a reset since Windows won't shutdown after XTCOM messes up the comm port
EPStool has dependencies on a specific version of python
I use flasher.exe which works well under Win7 except for the leaving flash mode quirk which is worked around by unplugging from the port.
Flasher has issues; it flashes expressif electrodragon firmware bins but has issues with others.
This is the cutting edge with esp8266 so getting cut with bad documentation imperfect firmware etc is very probable.
By villTech
#2086
gsgill112 wrote:1. XTCOM tools always fails to open the Serial com port.
make sure you selected the correct com port of usb to serial you are using.
By mcsa
#2088 Set terminal to 75000, and power up module. which messages appear?
In firmware update mode You must see
Code: Select all ets Jan  8 2013,rst cause:1, boot mode:(1,7)
