Chat freely about anything...
By Lawrence_jeff
#4404 As a follow up, this did seem to be a power issue, when powered through a bus pirate and capacitor the device could act as an AP and even receive data when connected to my AP but I could not update the firmware without it bombing after the erase stage.
I added in a 3.3 volt regulator powered off an external 5v supply and without any other changes the firmware update process started working via both ESPflash and the ESPTool.py tool
By GeoNomad
#4408 I found that one of my USB to Serial boards would be unreliable for flashing.
It tended to stop around 5-10% with different types of errors.
This was even when powering the ESP-x board with a separate power supply - which is always the first thing to check. Power off the USB to serial boards is often dirty or insufficient.
Anyway, I picked up a different USB to serial board and have not had a problem since.
Worth noting if you are having erratic problems during flashing.
Peter
Now at 5 x IoT ESP8266 thingies running 24/7 in my house. I am addicted... I wake up every morning with ideas to use this board...
