Does anybody know if the bootloader source is available anywhere? I'd love to use it as a starting point for some modifications I've got in mind. Also, it would be nice to silence it during boot to stop it spewing out boot messages.
Cheers,
Ben
Explore... Chat... Share...
RogerClark wrote:What do you mean by bootloader ?
Basically, AFIK none of the SDK libs or other low level code is available as source.
The only way to modify it would probably be to disassemble the SDK modify the assembler code and re-assemble.
Or if you just want to stop that message, you could probably find the bytes and replace with zeros to terminate the string.
There is a rom inside the chip that sets up the gpio's, mmc and spi and boots from there. You won;t find it in the SDK..
