eriksl wrote:And now it's in the release, together with your other request (tcp port timeouts)
Major changes: add access point mode.
Changelog:
- Fix issue where esp wouldn't start with default-config.
It appears some fields in the config struct aren't properly defaulted to 0.
- Add recipes in Makefile to backup current config, wipe it or restore it:
make backup-config
make restore-config
make wipe-config
This needs a programmer, it's done using esptool.
- Add gpio trigger for WLAN association
This triggers and I/O whenever
* client mode is connected and IP is obtained
* access point mode is active and a client connects
When the connection is dropped due to whatever reason, the trigger is reset.
- Drop major/minor version scheme. It's obsolete with the new (boot) configuration using access point mode.
- Add flexible end of line handling.
Any combination of \n \r \r\n and \n\r are now accepted as end of line delimiter. A line without any of them is now also accepted, as long as the command is sent in exactly one tcp segment.
- Add access point mode
* use the wac (wlan-accesspoint-config) command to select ssid, passwd, channel
* write the config using cw
* then use the wm (wlan-mode) command to select "ap" mode.
* login over the access point ssid and write the config (cw) to make
* the config permanent or issue a reset/power-cycle to return to client mode
* or use wm client to return to client mode
* use wcc (wlan-client-config) to select ssid, passwd and then issue cw to write to flash.
NOTE: for access point use a password longer than 7, it's required by the SDK.
- New "scratch" configuration mode
At startup the software will now try various schemes to obtain a connection so you can configure it.
1) if the device is configured to start in client mode, try the ssid/passwd stored in flash.
1a) if none is stored (flash is pristine/wiped or ssid/passwd invalid), use "esp" for ssid and "espespesp" for passwd.
1b) if the device cannot connect to the configured/default ssid for more then 30 seconds, change to access point mode -> 2)
2) if the device is configured to start in access point mode (or put in access point mode because of step 1b)), try the ssid/passwd stored in flash.
2a) if none is stored (flash is pristine/wiped or ssid/passwd invalid), use "esp" for ssid and "espespesp" for passwd.
That way you should always be able to connect to the esp.
https://github.com/eriksl/esp8266-unive ... ses/tag/14
bcn 0
del if1
usl
��sleep disable
mode : sta(5c:cf:7f:06:fa:4d)
add if0
* set wlan mode to ap, ssid="esp", passwd="espespesp", channel=13
del if0
usl
mode : softAP(5e:cf:7f:06:fa:4d)
add if1
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
bcn 100
bcn 0
del if1
usl
add if1
bcn 100
add 1
aid 1
station: 00:26:4d:1b:4d:2a join, AID = 1
chg_A3:-180
chg_A3:0
chg_A3:-180
u print-debug
cw
