By eriksl
#81706 I don't think you should use the pre-release, there are many issues with it. Please try an earlier version.
A new release is on it's way, with many issues resolved.
By holopaul
#81720
eriksl wrote:I don't think you should use the pre-release, there are many issues with it. Please try an earlier version.
I can hardly wait !
Can you tell me if and how can I do an OTA update when you publish the new release?
By eriksl
#81722 I completely forgot to tell that the sequencer uses flash storage that needs to be initialised. That's why you get the error.
Do this once "sec" (sequencer-clear) and you're good to go.
The last few versions can be upgraded over the air using "espflash", assuming you're using the OTA image and you have at least 2 Mbyte of flash installed.
By holopaul
#81736
eriksl wrote:The last few versions can be upgraded over the air using "espflash", assuming you're using the OTA image and you have at least 2 Mbyte of flash installed.
Both conditions are met but i have no clue about how "espflash" should be used
