regards ..
ESP8266 if good becasue use standard WiFi security ..
Explore... Chat... Share...
node in MESH are in deep sleep mode and are synchronized .. wake up every predefined time and listen or transmit .. WiFi MESH must work exactly same solution how in other low power MESH network..
Of course .. if ESP8266 can't change output power from +20db to (for example +0db or less) then must working in maximum
and what about transfer speed .. for example in nRF24L01+ send 32byte payload in 1Mbit speed then it's take less then 1ms .. but in 11Mbit or 54Mbit .. then can save lots of Tx time ..
