- Tue Mar 03, 2015 9:08 pm
#11228
chandan2002x wrote:@Bymasual, Thanks.
The locations are right.
I rechecked the uploaded firmware. Its working.
I believe, you are putting the ESP in run-mode (GPIO0 pull-up) after RESTting, and the serial baud rate is at 115200.
Anybody else are facing the same issue?
Edit:
However, I am adding fresh copy (V0.6) with little updated feature.
The AT+PINGROOT has been updated to AT+PINGROOT="............" . You can send data to Root node or co-ordinator. Data length is limited to 100 chars.
Thanks
Thank you for your response.
I tried with 0.6 and still nothing. I must be doing something wrong. I'm using NODEMCU Firmware programmer to flash. I connect CH_PD to 3.3v and GPIO0 to GND to flash. Afther flashing, I just disconnect GPIO0 from GND. No AP, nothing on serial, only when I connect RST to gnd I get the same string of garbage... 115200 baud on Arduino Monitor Serial with an CP2102.
EDIT: ok, now I'm getting serial output ( Scan starting...Data Scan Completed !!!! NO AP in MESH.Full Scan will be initiated), but it is not responding to AT commands(can't see the AP either). I flashed the v0.6, and then the files from the first bin.rar you uploaded:
eagle.app.v6.flash.bin --> 0x00000
eagle.app.v6.irom0text.bin -->0x40000
So it seems only with the bin's in "bin_0.6_03032015.rar" is not enough. Am I missing something here?
Again, thank you for your time.
