- Thu Jun 25, 2015 2:29 pm
#21666
The idea of a transparent bridge is very nice. Thank you for providing this software to the community.
I've tried to get it running with two different modules but not really successful.
First I have downloaded a firmware "AI-v0.9.5.0 AT Firmware.bin" to the module (somewhere I've read that a AT-Firmware >=0.92 has to be running on the module before downloading the transparent bridge binaries). After checking operation of the module by trying some AT commands (setting to Mode 3 AP+STA) and connecting with WLAN to the module I have downloaded the two firmware binaries from the github repository.
After powering up the module again tha AP is visible and I can connect and setup a telnet to the module. Once I get some characters out of the telnet which I typed at the serial terminal side but the other way around nothing was transmitted.
The telnet session was canceled by the module after around 30s.
If I put RST-pin to low in order to reset the module I get "MEM CHECK FAIL!!!" on both modules at 115200 baud. Reflashed a module back to 0.95 binary -> no "MEM CHECK FAIL!!!" -> flash transparent bridge again -> "MEM CHECK FAIL!!!" again on reset but not on power up start.
Which firmware version is proven to be work as base for the transparent bridge firmware images?
