I have found couple of tutorials where they say that the output of the USB to Serial converter Current is not enough for this and that i should use another power supply with voltage regulator
Do not use 3.3V pin of the USB to Serial converter to power the ESP8266 module because power supplied by the USB port is not sufficient to work the ESP8266 module.
So the tutorials connections looks like this :
But then i ask myself maybe this tutorials are old and the FT232RL model that i have has fixed output of 3.3v .
The FT232RL i am using has vcc output pin(which normaly output 3.3v) + another pin that writen on it 3.3v :
Also i have seen another tut where it can be connected directly :
http://rancidbacon.com/files/kiwicon8/E ... _1.0.4.pdf
Should i use another supply source ? or i can use the vcc output from the FT232RL ?
