I'm talking to an ESP with the arduino IDE serial moniter, through an arduino and a level shifter. About 1/5 of the time all the commands go through and I can use the module, but most of the time whenever I send the letter A it gets changed to Á (the A with a little mark above it). This is very frustrating because every command has AT in it, but the module receives ÁT and throws an error. If I keep sending the same command over and over eventually it will go through correctly, but that takes 5 to 10 tries. Does anyone have any advice for how to fix this? 4
