This is How I want it to be Done:
User Clicks Button on Webpage > PHP Script is Called > PHP Accesses the DataBase > Read & Write to It.
Community Help Me!
Explore... Chat... Share...
Ayush Sharma wrote:I Need a Mysql Database on My ESP8266 SPIFFS Memory . I Just need to know, that if i call a Php Script from my Webserver on ESP8266 , Then can it Write to the Database which is inside the SPIFFS Memory of the Module?
User Clicks Button on Webpage > PHP Script is Called > PHP Accesses the DataBase > Read & Write to It.![]()
