I'm new to ESP, trying to run the blink example. It seems to flash OK and I can receive the Serial prints back on the serial monitor, I don't have any LEDs lying around to truly test this, but it doesn't appear like GPIO2 is changing voltage at all.
Here's the code I'm running:
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
delay(10);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is acive low on the ESP-01)
Serial.print("Light is on.");
delay(1000); // Wait for a second
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
Serial.print("Light is off.");
delay(2000); // Wait for two seconds (to demonstrate the active low LED)
}Does anyone know why that might be happening?
