By beparas
#48690 Hi ALL,
I have 2 no. of ESP8266 module. I configure them by using AT command as follows.
Module 1 settings
AT+CWMODE=3
AT+CIPAP="192.168.1.0"
AT+CWSAP="esp_1","",1,0 [Note: for testing no password is set]
AT+CIPAP?
+CIPAP:ip:"192.168.1.0"
+CIPAP:gateway:"192.168.1.0"
+CIPAP:netmask:"255.255.255.0"
OK
AT+CWSAP?
+CWSAP:"esp_1","",1,0,4,0
OK
Module 2 settings
AT+CWMODE=3
AT+CIPAP="192.168.2.0"
AT+CWSAP="esp_2","",1,0 [Note: for testing no password is set]
AT+CIPAP?
+CIPAP:ip:"192.168.2.0"
+CIPAP:gateway:"192.168.2.0"
OK
AT+CWSAP?
+CWSAP:"esp_2","",1,0,4,0
OK
Now I want to connect to Module 1 from Module 2, so I send following command from Module 2.
AT+CWJAP="esp_1",""
WIFI CONNECTED
WIFI GOT IP
OK
Connection Ok. no problem.
Now I switch off Module 1, and send above command from module 2, my module 2 got reset with following log
AT+CWJAP="esp_1",""
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x40100000, len 816, room 16
tail 0
chksum 0x8d
load 0x3ffe8000, len 788, room 8
tail 12
chksum 0xcf
ho 0 tail 12 room 4
load 0x3ffe8314, len 288, room 12
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size : 32Mbit
jump to run user1
rlŽô
ready
Another observation is that.
After above error I restore the setting of Module 2 to factory setting by "AT+RESTORE" command and again configure Module 2 given by above steps.
Now when I fire connect command I got some response, In this case my module is not got reset. (Note: Module 1 is still switch off)
AT+CWJAP="esp_1",""
+CWJAP:3
FAIL
So My question is why module got reset in Test case 1.
What is meaning of "rst cause:4" in error log?
Thanks in advance.
