By Gorkde
#48776 Hello I did a project where the ESP was planned to be used just as WiFi.
Since I ran into problems with blynk disconnects and also seem to run out of memory before my program is finished anyway I'm thinking about switching to ESP Standalone.
My Questions:
1) How stable is ESP Standalone with Blynk? (disconnects etc)
2) I need some EEprom to save calibration data in case of power outage and read there is none on the ESP. Is there a way to save variables for this case?
3) Do I need to flash specific Firmware before or will this be done as soon as I upload my sketch with the Arduino IDE?
By MichaelRitter
#48928 1.Download the latest IDE which comes with ESP8266 compatibiliy.
http://www.arduino.cc/en/Main/Software
2.After installing, add ESP support to the IDE
Go to File – Preferences – in Preferences window go to “additional boards manager URL’s” where you need to
By logavanig
#48978 1.Download the latest IDE which comes with ESP8266 compatibiliy.
Go to File - Preferences - in Preferences window go to "additional boards manager URL's" where you need to paste the following link: https://adafruit.github.io/arduino-board-index/pa... adafruit link down(thx FrankHerrmann)
use this instead http://arduino.esp8266.com/package_esp8266com_inde...
- Click OK button.- Go to Tools - Boards - > Boards manager, in the Boards manager window select "contributed" from the TYPE drop - Select ESP8266 by ESP8266 community forum.
Press Install.
Before programming always remember to change board as ESP8266.
3. Also, I recommend adding the following libraries:
ESP8266 Arduino add-on by Sandeep mistry; follow instructions here https://github.com/sandeepmistry/esp8266-Arduino/b...
Add the blynk library https://github.com/blynkkk/blynk-library
If you do not know how to add library, go here https://www.arduino.cc/en/guide/libraries
I Hope This Will Helps you lot..
Thanks & Regards..
iOS Training in Chennai
