By chbla
#49140 Hi there,
I'm new to this and might ask stupid questions. I've got a couple of these boards:
http://www.aliexpress.com/item/NodeMcu- ... 97795.html
I want to use one of them as a night light under the bed (motion activated). So I wondered a) which LEDs to chose and b) how to connect them.
I don't have specs for this board so I have no idea about the real data, but I read that the GPIO pins usually have max 12ma current. Is this right? Would you go for standard 3.3V LEDs and just add a single LED to a couple of GPIOs in order to cover as much as possible? Or should I go for specific LEDs?
I couldn't find too many bright ones under 20ma so I would appreciate any kind of input..
Thanks a lot,
Christoph
By lethe
#49201 If you need more current, you can always use a transistor to switch the LEDs. A NDP6020P for example will allow you to switch more than 20A with a single GPIO, more than enough to burn your eyeballs out of their sockets ;)
Regarding your choice of LEDs: that depends on what you want to do with them and how much light you need.
Standard "super bright" 5mm LEDs should more than suffice for a night light.
If you want something more fancy, there are individually adressable RBG LEDs like WS2812b (or SK6812 which also comes as RGBW or white variants).
