By Dusk
#49486 Hi everyone ! :D
I hope someone can help me.. So.
I'd like to "talk" with my ESP8266-01, but when i write something in the "Serie Monitor" for my Arduino Uno, i can write commands like : "AT" (Without "") but when i tape enter, nothing appear ! So ..
My connections :
That's my code (French yeah :mrgreen: ) :
Code: Select all#include <SoftwareSerial.h>
#define DEBUG true
    SoftwareSerial ESP8266(10, 11);
    String NomduReseauWifi = "Bbox-E78"; // Garder les guillements
    String MotDePasse      = "4C5ACAE33AAE4F6D67F1E"; // Garder les guillements
    String NameESP = "ESP8267";
    String mdpEsp = "123";
    String channel = "3";
    String WPA_PSK = "2";
    /*                             INIT                             */
    void setup()
      Serial.begin(9600);
      ESP8266.begin(115200);
      envoieAuESP8266("AT+RST");
      envoieAuESP8266("AT+CIOBAUD=9600");
      recoitDuESP8266(4000);
      ESP8266.begin(9600);
      /*while(1){initESP8266();}*/
      initESP8266();
    /*                        BOUCLE INFINIE                        */
    void loop()
       while(ESP8266.available())
         Serial.println(ESP8266.readString());
       if(ESP8266.find("+IPD,"))
           delay(1000);
           int connectionId = ESP8266.read()-48; // subtract 48 because the read() function returns
                                                 // the ASCII decimal value and 0 (the first decimal number) starts at 48
           String webpage = "<h1>Hello</h1>&lth2>World!</h2><button>LED1</button>";
           String cipSend = "AT+CIPSEND=";
           cipSend += connectionId;
           cipSend += ",";
           cipSend +=webpage.length();
           cipSend +="\r\n";
           envoieAuESP8266(cipSend);
           envoieAuESP8266(webpage);
           webpage="<button>LED2</button>";
           cipSend += ",";
           cipSend +="\r\n";
           String closeCommand = "AT+CIPCLOSE=";
           closeCommand+=connectionId; // append connection id
           closeCommand+="\r\n";
           envoieAuESP8266(closeCommand);
    /*                Fonction qui initialise l'ESP8266             */
    void initESP8266()
      Serial.println("**********************************************************");
      Serial.println("**************** DEBUT DE L'INITIALISATION ***************");
      envoieAuESP8266("AT");
      recoitDuESP8266(2000);
      recoitDuESP8266(5000);
      envoieAuESP8266("AT+CWSAP?");
      envoieAuESP8266("AT+CWMODE=3");
      envoieAuESP8266("AT+CWJAP=\""+ NomduReseauWifi + "\",\"" + MotDePasse +"\"");
      recoitDuESP8266(10000);
      envoieAuESP8266("AT+CIFSR");
      recoitDuESP8266(1000);
      envoieAuESP8266("AT+CIPMUX=1");
      envoieAuESP8266("AT+CIPSERVER=1,80");
      recoitDuESP8266(500);
      Serial.println("***************Config*************************");
      envoieAuESP8266("AT+CWSAP=\""+ NameESP + "\",""\"" + mdpEsp + "\"," + channel + "," + WPA_PSK +"");
      Serial.println("**************Regarde si bien configure**********************");
      Serial.println("**************************DHCP****************************");
      envoieAuESP8266("AT+CWDHCP=2,1");
      Serial.println("***************** INITIALISATION TERMINEE ****************");
      Serial.println("");
    /*        Fonction qui envoie une commande à l'ESP8266          */
    void envoieAuESP8266(String commande)
      ESP8266.println(commande);
    /*Fonction qui lit et affiche les messages envoyés par l'ESP8266*/
    void recoitDuESP8266(const int timeout)
      String reponse = "";
      long int time = millis();
      while( (time+timeout) > millis())
          char c = ESP8266.read();
          reponse+=c;
      Serial.print(reponse);
All responses :
Code: Select all
AT
OK
AT+RST
OK
WIFI DISCONNECT
bBÖ†øRcjþÈÉ¥SNÊÉ¥SNÂI�ë"B„n"jˆBĵ
Ai-Thinker Technology Co.,Ltd.
invalid
WIFI CONNECTED
WIFI GOT IP
AT+CWSAP?
+CWSAP:"ESP8266","123",1,0,4
OK
AT+CWMODE=3
OK
AT+CWJAP="Bbox-E78","4C5ACAE33AAE4F6D67F1E"
WIFI DISCONNECT
WIFI CONNECTED
WIFI GOT IP
OK
AT+CIFSR
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"5e:cf:7f:84:86:d2"
+CIFSR:STAIP,"192.168.1.87"
+CIFSR:STAMAC,"5c:cf:7f:84:86:d2"
OK
AT+CIPMUX=1
OK
AT+CIPSERVER=1,80
OK
AT+CWSAP="ESP8267","123",3,2
[color=#FF0000]ERROR[/color]
AT+CWSAP?
OK
AT+CWDHCP=2,1
OK
Configuration are OK, that's work ! But when i try to enter command, don't work, don't write anything ..
Configuration not ok to the : ERROR (Config)
I tried to work with ESPlorer, i can connect, but nothing more ! :(
So, if you can help me, i'll be very happy ! And sorry for my english if it's not good.
Thanks you ! :)
By Dusk
#49660 Ok
Found something to solve it :
add
Code: Select all        if (ESP8266.available()) {
          Serial.write(ESP8266.read());
        if (Serial.available()) {
          ESP8266.write(Serial.read());
in function loop.
