I'm a student, I wonder if tm4c123gxl can write firmware to esp8266, because I see tm4c has Tx and Rx pins, or I have to buy a USB to TTL ?
Here is my firmware I want to flash to esp8266
https://github.com/tuanpmt/esp_mqtt
Thank you very much
Explore... Chat... Share...
