Has anyone else had experience with porting an ethernet based library to wifi or how to fix these errors.
Thank you.
In file included from \Documents\Arduino\libraries\Settimino\Settimino.h:42:0,
from \Documents\Arduino\libraries\Settimino\Settimino.cpp:26:
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = unsigned char [22]; size_t = unsigned int]':
\Documents\Arduino\libraries\Settimino\Settimino.cpp:426:41: required from here
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'unsigned char [22]'
size_t left = source.available();
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'unsigned char [22]'
source.read(buffer.get(), will_send);
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = unsigned char [25]; size_t = unsigned int]':
\Documents\Arduino\libraries\Settimino\Settimino.cpp:446:39: required from here
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'unsigned char [25]'
C:\Users\Geoff-Work\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'unsigned char [25]'
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = unsigned char [35]; size_t = unsigned int]':
\Arduino\libraries\Settimino\Settimino.cpp:543:34: required from here
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'unsigned char [35]'
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'unsigned char [35]'
exit status 1
Error compiling.
