cs_enable();
spi_tx8(spinum,cts_check_cmd);
cts_byte = (unsigned char)spi_rx8(spinum);
cs_disable()The problem is, the above only works when I put it in a while(1) loop within the user_init function, which executes these lines repeatedly and I can see the pulses on the DSO. The weird part is, the above does not work when called just once within the user_init main. It only works when executed within a while(1) loop.
I need to execute the above statements just once during initialization and capture the signals in the DSO which I am able to do so only when executed within a while(1) loop. What am I missing and why it work only when called repeatedly in while loop?
Between, I am not using any rtos. Doing the above using non os sdk.
