It's current pricing shown is 1000 yuan = 149.65USD. I'm not sure if this is an error but look forward for it!
Explore... Chat... Share...
lethe wrote:That picture does not look like the module is using an ESP12 form factor. It seems to have way more pins, so it must be either larger than an ESP12 or use a narrower pin spacing (the similar name is probably just for marketing).
