By rudy
#54483 Found at https://github.com/CytronTechnologies/ESP8266-WiFi-Module
Four outputs right now. Some inverted states due to some leds hooked up pull up and some pull down.
There also was a handy Windows program to convert html code to the text .h file formatting needed for the .ino included file. convertHtml.exe I tried it and it and it worked as expected.
Code: Select all/*
  ESP8266 mDNS responder sample
  This is an example of an HTTP server that is accessible
  via http://esp8266.local URL thanks to mDNS responder.
  Instructions:
  - Update WiFi SSID and password as necessary.
  - Flash the sketch to the ESP8266 board
  - Install host software:
    - For Linux, install Avahi (http://avahi.org/).
    - For Windows, install Bonjour (http://www.apple.com/support/bonjour/).
    - For Mac OSX and iOS support is built in through Bonjour already.
  - Point your browser to http://esp8266.local, you should see a response.
#include <ESP8266mDNS.h>
#include <WiFiClient.h>
#include "ioControl.h"
const char* ssid = "esp";
const char* password = "12345678";
const int output12 = 12;
const int output13 = 13;
const int output14 = 14;
const int output16 = 16;
// multicast DNS responder
MDNSResponder mdns;
// TCP server at port 80 will respond to HTTP requests
WiFiServer server(80);
void setup(void)
  // Connect to WiFi network
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.println(ssid);
  Serial.print("IP address: ");
  // Set up mDNS responder:
  // - first argument is the domain name, in this example
  //   the fully-qualified domain name is "esp8266.local"
  // - second argument is the IP address to advertise
  //   we send our IP address on the WiFi network
  if (!mdns.begin("esp8266", WiFi.localIP())) {
    Serial.println("Error setting up MDNS responder!");
    while(1) {
      delay(1000);
 Serial.println("mDNS responder started");
  // Start TCP (HTTP) server
  server.begin();
  Serial.println("TCP server started");
  delay(2000);
  Serial.end();
  pinMode(12,OUTPUT);//active high
  pinMode(13,OUTPUT);digitalWrite(1,HIGH); //active low
  pinMode(14,OUTPUT);//active high
  pinMode(16,OUTPUT);//active high
void loop(void)
  if (!client) {
    return;
  // Wait for data from client to become available
  while(client.connected() && !client.available()){
    delay(1);
  // Read the first line of HTTP request
  // First line of HTTP request looks like "GET /path HTTP/1.1"
  // Retrieve the "/path" part by finding the spaces
  int addr_start = req.indexOf(' ');
  int addr_end = req.indexOf(' ', addr_start + 1);
  if (addr_start == -1 || addr_end == -1) {
    return;
  req = req.substring(addr_start + 1, addr_end);
  client.flush();
  String s;
  if (req == "/")
    s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
    s += file1;
  else if (req.indexOf("gpio0")!=-1)
    if(req.indexOf("on")!=-1)
    digitalWrite(14,LOW);  //HIGH);
    digitalWrite(14,HIGH);  //LOW);
    s += file1;
  else if (req.indexOf("gpio1")!=-1)
    digitalWrite(12,LOW);
    digitalWrite(12,HIGH);
    s += file1;
  else if (req.indexOf("gpio2")!=-1)
    digitalWrite(13,LOW);  //HIGH);
    digitalWrite(13,HIGH);  //LOW);
    s += file1;
  else if (req.indexOf("gpio3")!=-1)
    digitalWrite(16,LOW);  //HIGH);
    digitalWrite(16,HIGH);  //LOW);
    s += file1;
    s = "HTTP/1.1 404 Not Found\r\n\r\n";
  while(s.length()>2000)
   String dummy = s.substring(0,2000);
   client.print(dummy);
   s.replace(dummy,"");
  client.print(s);
Put the following in a file called ioControl.h
Code: Select all#ifndef header_h
#define header_h
String file1=
"<html>\r\n"
"<head>\r\n"
"   <title>ESP8266 GPIO Control</title>\r\n"
"</head>\r\n"
"<body>\r\n"
"<h2>ESP8266 GPIO Control</h2>\r\n"
"\r\n"
"<form action = \"/gpio0\" method=\"GET\">GPIO 0: G <input type=\"submit\" name=\"on\" value=\"ON\"/>&nbsp;<input type=\"submit\" name=\"off\" value=\"OFF\"/>&nbsp;</form>\r\n"
"<form action = \"/gpio1\" method=\"GET\">GPIO 1: R <input type=\"submit\" name=\"on\" value=\"ON\"/>&nbsp;<input type=\"submit\" name=\"off\" value=\"OFF\"/>&nbsp;</form>\r\n"
"<form action = \"/gpio2\" method=\"GET\">GPIO 2: Y <input type=\"submit\" name=\"on\" value=\"ON\"/>&nbsp;<input type=\"submit\" name=\"off\" value=\"OFF\"/>&nbsp;</form>\r\n"
"<form action = \"/gpio3\" method=\"GET\">GPIO 3: B <input type=\"submit\" name=\"on\" value=\"ON\"/>&nbsp;<input type=\"submit\" name=\"off\" value=\"OFF\"/>&nbsp;</form>\r\n"
"\r\n"
"</body>\r\n"
"</html>\r\n";
#endif
