- Tue Oct 04, 2016 10:16 pm
#56076
The video is not done yet and this is a project I wish can be done.
However Arduino IDE latest version cannot work with my NodeMCU V3 even with a simple blink sketch. I had tried to flash with ESP8266flasher and use ESPlorer which I can login to my wifi and also blink some leds. But Arduino IDE seems keep giving errors and I am quite busy these few months to meddle.
Pi is way too advance comparing to ESP8266, you cannot compare them.
I had asked many people and seems most people said impossible because the CPU is slow and the ram is far too low. After some research, I found out that taking pictures with ESP8266 maybe OK but if processing them into a video will be not enough frame rate and you will notice slow motion video. Slow motion is bad and I tried with my usb camera, you need at least 8 frame/second. I do not think NodeMCU V3 is up to the task with that little ram. Perhaps the cpu is just at the margin but those ram size are too small for video.
