By bananasplit
#55630 hello there!i m having some problems with esp8266 201..even if i ve powered it with a (more than enough) power supply,it keeps restarting itself..i ve uploaded this code,that is used to connect to Cayenne and add some sensors to it,and even if it sometimes connect to the internet and cayenne discovers it,then it gets offline and online again.and after sometime it stops getting online,unless i power it down and up again.any ideas?maybe there is a "sleep" function?but i dont see anything like this in the code.any ideas??
Code: Select all/*
#include <SoftwareSerial.h>                               //SoftwareSerial library required for Arduino communication with the Grove RFID reader and the Grove Serial MP3 player
#include <BlynkSimpleEsp8266.h>
#include "CayenneDefines.h"
#include "CayenneWiFiClient.h"
char token[] = "";        //Cayenne authentication token. This should be obtained from the Cayenne Dashboard.
// Your network name and password.
char ssid[] = "";
char password[] = "";
SoftwareSerial mp3(2,3);                                  //Grove Serial MP3 Player is connected to Digital Pins 2 and 3
SoftwareSerial rfid(10,11);                               //Grove 125kHz RFID reader is connected to Digital Pins 10 and 11 (Note: lower pins may not work with this board)
//Global Variables
int rfidValue = 0;                                        //rfidValue: used to store the value obtained from the RFID tag
int vPin6 = 0;                                            //vPin6: is associated with Virtual Pin 6 on the Cayenne Dashboard - activated when a person is detected by the sensors.
int vPin7 = 0;                                            //vPin7: is associated with Virtual Pin 7 on the Cayenne Dashboard - activated when the person fails to identify themselves.
unsigned long start_Time;                                 //start_Time: is used in various time related events (logs the start time)
unsigned long stop_Time;                                  //stop_Time: is used in various time related events (logs the stop time)
unsigned long time_Diff = 0;                              //time_Diff: is used in various time related events (is used to record the time elapsed from start time to stop time)
boolean keyMessagePlayed=false;                           //keyMessagePlayed: helps to prevent a message from replaying repeatedly when a person is detected.
boolean waitingForKey = true;                             //waitingForKey: is used to identify if we are still waiting for a person to present a valid key or not
int songNumber = -1;                                      //songNumber is a variable used to hold the song number to play (from the playlist on the SD card on the MP3 player)
/*===============================setup()============================================================================================================================= */
void setup(){
  delay(2500);                                            //Delay for 2.5 seconds to allow the Grove MP3 player to initialise
  mp3.begin(9600);                                        //Establish a communication link with the Grove MP3 player
  rfid.begin(9600);                                       //Establish a communication link with the Grove 125 kHz RFID reader
  Serial.begin(9600);                                     //Establish a communication link with my computer (via the Serial monitor) - for debugging purposes.
  Cayenne.begin(token, ssid, password);                                   //Establish a communication link with the Cayenne Server - the token must match that in the Cayenne Dashboard
  setVolume(28);                                          //Set the volume of the MP3 player to 28 (Range = 0 to 31, whereby 31 is maximum volume)
  setPlayMode(0x00);                                      //Configure the MP3 player to play the MP3 file ONCE only (per request).
/*===============================loop()============================================================================================================================= */
void loop(){
  Cayenne.run();                                          //Synchronise with the Cayenne Server
  if(vPin6&&!vPin7){                                      //Only progress if Virtual Pin 6 (Person detection) is ACTIVATED but ONLY when Virtual Pin 7 (Intruder alert) has NOT already been activated.
    if(!keyMessagePlayed){                                //This ensures that the message is played only ONCE when a person has been detected.
      playSong(1);                                        //Play the following message on the Grove MP3 player: "Place your keys on the mat"
      keyMessagePlayed=true;                              //keyMessagePlayed is changed to TRUE once the message has been played.
     /*This section requests the Arduino to look out for the person's keys, and returns TRUE when a successful identification is made.
      * It returns FALSE if the person fails to put their keys on the Mat within 10 seconds , OR if the person cannot be identified by the Arduino (e.g. Wrong code)
      * If a person has been successfully identified/verified, it will play a welcome message, and switch off the "Person Detection Trigger", which will then
      * be used as a method to switch off the Security scanning process.
      * If a person fails to be identified within 10 seconds, the person is notified that they have been detected, and an Alarm will sound.
      * Virtual Pin 7 (Intruder Alert) will be ACTIVATED - which will be used as a Trigger within Cayenne to notify me of an Intruder (via Email or SMS).
    if(listenForKeys()){
      //TRUE = Person Identified within 10 seconds
      playSong(songNumber);                               //Play message "Welcome Home - Scott"
      vPin6 = 0;                                          //Deactivate the "Person Detection" virtual pin (6).
      keyMessagePlayed=false;                             //Reset the keyMessagePlayed variable for future detections.
    } else {
      //FALSE = Person not identified within 10 seconds
      playSong(2);                                        //Play message on Grove MP3 player : "Your presence has been detected"
      delay(4000);                                        //A FOUR second delay is required to allow the message to play, before the alarm sounds.
      playSong(3);                                        //Sound the ALARM by playing song 2 on the Grove MP3 player. Song numbers are determined by the order they have been written to the SD card.
      delay(8000);                                        //An EIGHT second delay allows the alarm to sound for 8 seconds.
      playSong(99);                                       //Playing a non-existing track essentially STOPS the MP3 player.
      vPin7=1;                                            //ACTIVATE Virtual Pin 7 - Intruder Detected
    upDateCayenne();                                      //Update the Cayenne Dashboard with any changes made to the virtual pins (6 or 7). This method can be found below.
/*=writeToMP3 function======================================================================================================================================================
 * is used to simplify the process of sending commands to the Grove MP3 player
void writeToMP3(byte MsgLEN, byte A, byte B, byte C, byte D, byte E, byte F){
  byte codeMsg[] = {MsgLEN, A,B,C,D,E,F};
  mp3.write(0x7E);                                        //Start Code for every command = 0x7E
  for(byte i = 0; i<MsgLEN+1; i++){
    mp3.write(codeMsg[i]);                                //Send the rest of the command to the GROVE MP3 player
/*=setVolume function======================================================================================================================================================
 * is used to simplify the process of setting the Volume on the Grove MP3 player
 * Volume range = 00 (muted) to 31 (max volume)
void setVolume(byte Volume){
  byte tempVol = constrain(Volume, 0, 31);                //Ensure the Volume does not extend beyond the MP3 player's limits
  writeToMP3(0x03, 0xA7, tempVol, 0x7E, 0x00, 0x00, 0x00);
/*=setPlayMode function======================================================================================================================================================
 * is used to simplify the process of setting up the play Mode on the Grove MP3 player
 * playMode options:
 *      0x00 = Single song - played only once ie. not repeated.  (default)
 *      0x01 = Single song - cycled ie. repeats over and over.
 *      0x02 = All songs - cycled
 *      0x03 = play songs randomly
void setPlayMode(byte playMode){
  writeToMP3(0x03, 0xA9, playMode, 0x7E, 0x00, 0x00, 0x00);
/*=playSong function======================================================================================================================================================
 * is used to simplify the process of playing a specific track on the SD card of the Grove MP3 player.
 * The track number is determined by the order in which the songs were written to the SD card.
 * Best to name the tracks in sequence, e.g.  0000_Song0.mp3   ,   0001_Song1.mp3    etc etc.
 * And also best to copy them one by one to the SD card from Song 0 to Song x.
void playSong(byte songNum){
  writeToMP3(0x04, 0xA0, 0x00, songNum, 0x7E, 0x00, 0x00);
/*=listenForKeys function======================================================================================================================================================
 * is used to identify the person detected.
 * The Arduino will wait a maximum of 10 seconds for the person to place their RFID tag near the Grove RFID reader antenna.
 * This example shows two RFID tag values that will be accepted.
 * This method also prints the RFID tag value to the Serial monitor - for debugging purposes.
boolean listenForKeys(){
  //reset some variables every time this function is called.
  songNumber = -1;
  start_Time = millis();
  time_Diff = 0;
  rfidValue=0;
  //Wait for a valid RFID tag for a maximum of 10 seconds
  while(time_Diff<10000 && waitingForKey){
     Cayenne.run();                                       //Make sure to stay in contact with the Cayenne Server while waiting for the RFID tag.
     stop_Time = millis();
     time_Diff = stop_Time - start_Time;                  //Measure the time elapsed.
     //If an RFID tag is detected by the Grove RFID reader, it will transmit a series of numbers related to the Tag ID.
     if(rfid.available()){
        while(rfid.available()){                          //Make sure to read all of the numbers transmitted by the Grove RFID reader
          rfidValue += rfid.read();                       //You could employ a method to extract the exact RFID Tag ID - however just adding each number received -  produced a unique number that I could use to identify the person.
          delay(1);                                       //A small delay between reads - ensures you get all of the numbers from the RFID reader in one go.
        Serial.println("RFID VALUE:");
        Serial.println(rfidValue);                        //Print the Unique RFID Tag value to the Serial monitor - useful for debugging
        //If a person has an RFID tag that can be identified in this list, then play a personalised message for that person.
        switch(rfidValue){
          case 628:                                       //Person #1 has a Tag that generates an rfidValue of 628.
            songNumber=4;                                 //File#4 (or message number 4) on the Grove MP3 player will be played when this person is detected.
            waitingForKey = false;                        //setting the "waitingForKey" variable to FALSE - will allow us to break out of the while loop (instead of waiting for a full 10 seconds).
            break;
          case 651:                                       //Person #2 has a Tag that generates an rfidValue of 651.
            songNumber=5;                                 //File#5 (or message number 5) on the Grove MP3 player will be played when this person is detected.
            break;
          case 694:                                       //Person #3 has a Tag that generates an rfidValue of 694.
            songNumber=6;                                 //File#6 (or message number 6) on the Grove MP3 player will be played when this person is detected.
            break;
          case 658:                                       //Person #4 has a Tag that generates an rfidValue of 658.
            songNumber=7;                                 //File#7 (or message number 7) on the Grove MP3 player will be played when this person is detected.
            break;
          case 677:                                       //Person #5 has a Tag that generates an rfidValue of 677.
            songNumber=8;                                 //File#8 (or message number 8) on the Grove MP3 player will be played when this person is detected.
            break;
          default:
            waitingForKey = true;                         //If a person has not been identified, keep waiting for the key/tag until the times runs out.
            break;
  /* If we are still waiting for an RFID tag (key) at this point, then we were unsuccessful in identifying the person within 10 seconds.
   *  Returning FALSE - will sound the alarm, and will activate Virtual Pin 7 (Intruder Alert).
   *  Returning TRUE - means that we have identified the person who triggered the sensors, and can therefore relax, and turn OFF the Security sensors.
  if(waitingForKey){
    return false;
  } else {
    return true;
/*=upDateCayenne function======================================================================================================================================================
 * This function will transmit the values of vPin6 and vPin7 to the Cayenne Dashboard's Virtual Pin 6 and 7 (respectively).
 * This will help the Cayenne Server to keep up to date with the status of each variable.
void upDateCayenne() {
  Cayenne.virtualWrite(V6, vPin6);
  delay(50);
  Cayenne.virtualWrite(V7, vPin7);
  delay(50);
/*=CAYENNE_IN(V6) function======================================================================================================================================================
 * This will update the Arduino's vPin6 variable to the same value as Virtual Pin 6 on the Cayenne Dashboard.
 * Which means that you can control the value of vPin6 from the Cayenne app.
CAYENNE_IN(V6){
  vPin6 = getValue.asInt();
/*=CAYENNE_IN(V7) function======================================================================================================================================================
 * This will update the Arduino's vPin7 variable to the same value as Virtual Pin 7 on the Cayenne Dashboard.
 * Which means that you can control the value of vPin7 from the Cayenne app.
CAYENNE_IN(V7){
  vPin7 = getValue.asInt();
